On Design of Sampled-Data Interval Observers
New design of interval observers for continuous-time systems with discrete-time measurements is proposed. Positivity and stability conditions are obtained using the time-delay approach. Next, control is synthesized based on interval estimates. Efficiency of the obtained solution is demonstrated on examples.
Automatique / Robotique
