On Design of Sampled-Data Interval Observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
New design of interval observers for continuous-time systems with discrete-time measurements is proposed. Positivity and stability conditions are obtained using the time-delay approach. Next, control is synthesized based on interval estimates. Efficiency of the obtained solution is demonstrated on examples.
ECC16_0411_FI.pdf (290.19 Ko) Télécharger le fichier
hal-01295752 , version 1 (31-03-2016)
  • HAL Id : hal-01295752 , version 1
Denis Efimov, Emilia Fridman, Andrey Polyakov, Wilfrid Perruquetti, Jean-Pierre Richard. On Design of Sampled-Data Interval Observers. European Control Conference (ECC16), Mar 2016, Aalborg, Denmark. ⟨hal-01295752⟩
221 Consultations
213 Téléchargements
