On abstract Barenblatt equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Differential Equations and Applications Année : 2011
In this paper we are interested in abstract problems of Barenblatt's type. In a first part, we investigate the problem f (∂ t u) + Au = g where f and A are maximal monotone operators and by assuming that A derives from a potential J. With general assumptions on the operators, we prove the existence of a solution. In the second part of the paper, we examine a stochastic version of the above problem: f [∂ t (u − t 0 hdw)] + Au = 0 , with some restrictive assumptions on the data due principally to the framework of the Itô integral.
dea-03-31.pdf (212.43 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01309490 , version 1 (29-04-2016)
Caroline Bauzet, Guy Vallet. On abstract Barenblatt equations. Nonlinear Differential Equations and Applications, 2011, 3 (4), pp.487-502. ⟨10.7153/dea-03-31⟩. ⟨hal-01309490⟩
84 Consultations
90 Téléchargements
