Optimal control of PDEs in a complex space setting; application to the Schrödinger equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2019
In this paper we discuss optimality conditions for abstract optimization problems over complex spaces. We then apply these results to optimal control problems with a semigroup structure. As an application we detail the case when the state equation is the Schrödinger one, with pointwise constraints on the "bilinear'" control. We derive first and second order optimality conditions and address in particular the case that the control enters the state equation and cost function linearly.
ABK_2016_v1.pdf (359.98 Ko) Télécharger le fichier
hal-01311421 , version 1 (04-05-2016)
Maria Soledad Aronna, Joseph Frédéric Bonnans, Axel Kröner. Optimal control of PDEs in a complex space setting; application to the Schrödinger equation. SIAM Journal on Control and Optimization, 2019, 57 (2), pp.1390-1412. ⟨10.1137/17M1117653⟩. ⟨hal-01311421⟩
610 Consultations
370 Téléchargements
