New interface
Reports (Research report)
Traitement de données bioinformatiques massives (Big Data)
Sarah Cohen-Boulakia 1, 2, 3, 4 Patrick Valduriez 3, 4
1 VIRTUAL PLANTS - Modeling plant morphogenesis at different scales, from genes to phenotype
CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique, UMR AGAP - Amélioration génétique et adaptation des plantes méditerranéennes et tropicales
3 ZENITH - Scientific Data Management
LIRMM - Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : The volumes of bioinformatics data available on the Web are constantly increasing. Access and joint exploitation of these highly distributed data (i.e, available in distributed Web data sources) and highly heterogeneous (in text or tabulated les including images, in di erent formats, described with di erent levels of detail and di erent levels of quality ...) is essential for the biological knowledge to progress. The purpose of this short report is to present in a simple way the problems of the joint use of bioinformatics data.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01321033
Contributor : Patrick Valduriez Connect in order to contact the contributor
Submitted on : Tuesday, May 24, 2016 - 5:11:25 PM
Last modification on : Wednesday, October 26, 2022 - 8:14:34 AM
File
RR-8915.pdf
Identifiers
  • HAL Id : hal-01321033, version 1
Citation
Sarah Cohen-Boulakia, Patrick Valduriez. Traitement de données bioinformatiques massives (Big Data). [Rapport de recherche] RR-8915, Inria Sophia Antipolis; LRI - CNRS, University Paris-Sud. 2016, pp.8. ⟨hal-01321033⟩
Share
Metrics
Record views
2473
Files downloads
1244
