CONTROL OF UNDERWATER VEHICLES IN INVISCID FLUIDS–II. FLOWS WITH VORTICITY - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In a recent paper, the authors investigated the controllability of an underwater vehicle immersed in an infinite volume of an inviscid fluid, assuming that the flow was irrotational. The aim of the present paper is to pursue this study by considering the more general case of a flow with vorticity. It is shown here that the local controllability of the position and the velocity of the underwater vehicle (a vector in R 12) holds in a flow with vorticity whenever it holds in a flow without vorticity.
LR-final2.pdf (357.05 Ko) Télécharger le fichier
hal-01323698 , version 1 (31-05-2016)
Rodrigo Lecaros, Lionel Rosier. CONTROL OF UNDERWATER VEHICLES IN INVISCID FLUIDS–II. FLOWS WITH VORTICITY. 2016. ⟨hal-01323698⟩
291 Consultations
60 Téléchargements
