On the Benjamin-Bona-Mahony equation with a localized damping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Lionel Rosier
We introduce several mechanisms to dissipate the energy in the Benjamin-Bona-Mahony (BBM) equation. We consider either a distributed (localized) feedback law, or a boundary feedback law. In each case, we prove the global wellposedness of the system and the convergence towards a solution of the BBM equation which is null on a band. If the Unique Continuation Property holds for the BBM equation, this implies that the origin is asymp-totically stable for the damped BBM equation.
rosier-BBM.pdf (118.59 Ko) Télécharger le fichier
hal-01323704 , version 1 (31-05-2016)
Lionel Rosier. On the Benjamin-Bona-Mahony equation with a localized damping. 2016. ⟨hal-01323704⟩
143 Consultations
195 Téléchargements
