Dendriform structures for restriction-deletion and restriction-contraction matroid Hopf algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2016
We endow the set of isomorphism classes of matroids with a new Hopf algebra structure, in which the coproduct is implemented via the combinatorial operations of restriction and deletion. We also initiate the investigation of dendriform coalgebra structures on matroids and introduce a monomial invariant which satisfy a convolution identity with respect to restriction and deletion.
2714-9868-1-PB.pdf (243.4 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01352851 , version 1 (16-08-2016)
Nguyen Hoang-Nghia, Adrian Tanasa, Christophe Tollu. Dendriform structures for restriction-deletion and restriction-contraction matroid Hopf algebras. Discrete Mathematics and Theoretical Computer Science, 2016, Vol. 17 no. 3 (3), pp.77-90. ⟨10.46298/dmtcs.2157⟩. ⟨hal-01352851⟩
80 Consultations
859 Téléchargements
