Linear recognition of generalized Fibonacci cubes $Q_h(111)$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2016
The generalized Fibonacci cube $Q_h(f)$ is the graph obtained from the $h$-cube $Q_h$ by removing all vertices that contain a given binary string $f$ as a substring. In particular, the vertex set of the 3rd order generalized Fibonacci cube $Q_h(111)$ is the set of all binary strings $b_1b_2 \ldots b_h$ containing no three consecutive 1's. We present a new characterization of the 3rd order generalized Fibonacci cubes based on their recursive structure. The characterization is the basis for an algorithm which recognizes these graphs in linear time.
2756-9997-1-PB.pdf (308.9 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01364442 , version 1 (12-09-2016)
Yoomi Rho, Aleksander Vesel. Linear recognition of generalized Fibonacci cubes $Q_h(111)$. Discrete Mathematics and Theoretical Computer Science, 2016, Vol. 17 no. 3 (3), pp.349-362. ⟨10.46298/dmtcs.2165⟩. ⟨hal-01364442⟩
Collections
TDS-MACS
54 Consultations
795 Téléchargements
