Kinematic Modeling and Observer Based Control of Soft Robot using Real-Time Finite Element Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper aims at providing a novel approach to modeling and controlling soft robots. Based on real-time Finite Element Method (FEM), we obtain a globally defined discrete-time kinematic model in the workspace of soft robots. From the kinematic equations, we deduce the soft-robot Jacobian matrix and discuss the conditions to avoid singular configurations. Then, we propose a novel observer based control methodology where the observer is built by Finite Element Model in this paper to deal with the control problem of soft robots. A closed-loop controller for position control of soft robot is designed based on the discrete-time model with feedback signal being extracted by means of visual servoing. Finally, experimental results on a parallel soft robot show the efficiency and performance of our proposed controller.
IROS16_0629_FI.pdf (2.05 Mo) Télécharger le fichier
hal-01370347 , version 1 (22-09-2016)
  • HAL Id : hal-01370347 , version 1
Zhongkai Zhang, Jeremie Dequidt, Alexandre Kruszewski, Frederick Largilliere, Christian Duriez. Kinematic Modeling and Observer Based Control of Soft Robot using Real-Time Finite Element Method. IROS2016 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Oct 2016, Daejeon, South Korea. ⟨hal-01370347⟩
695 Consultations
1458 Téléchargements
