An AUML State Machine Based Method for Multi-agent Systems Model Checking
This paper firstly proposes a Multi-agent System Model Checking Framework, which is based on AUML (Agent Unified Modeling Language) state machine model and temporal logics of knowledge and provides a method using AUML state machine for Multi-Agent Systems formal modeling. Then a method for the conversion from AUML state machine formal description to ISPL language is proposed. Finally a simulation is accomplished with the conversion tool AUML2ISPL.
Informatique [cs]
