Lossy compression of unordered rooted trees
A classical compression method for trees is to exploit subtree repeats in the structure by
representing them by directed acyclic graphs. We propose a lossy compression method that
consists in computing a structure with high redundancy that approximates the initial data.
Trees are commonly used to represent hierarchical data appearing in computer
science or in biology. Compression methods often take advantage of repeated substructures
appearing in the tree (see the survey [1]). Directed Acyclic Graph (DAG)
compression is a classical approach that exploits subtree repeats in the structure.
However, it should be noted that trees without a high level of redundancy are often
insufficiently compressed by this procedure. Self-nested trees are such that all their
complete subtrees of a given height are isomorphic. The systematic repetition of
subtrees gives them remarkable compression properties by this approach.
We address lossy compression for unordered trees. Loss can be acceptable for
visual representation of scenes composed of plants, for example. Our method consists
in computing the DAG version of a self-nested tree that closely approximates the tree
to compress. A first approximation has been proposed in [2] in which the authors
compute in polynomial time the Nearest Embedding Self-nested Tree (NEST) of the
initial structure, namely the self-nested tree that minimizes the edit distance to the
initial tree and that embeds it. We focus on the presentation of two new algorithms to
find a self-nested structure that approximates the initial tree better than the NEST.
These solutions rely on a technique to find the centroid of a forest of small height
and may be computed in polynomial time for trees with bounded degree. We prove
on a simulated dataset that the error rates of these lossy compression methods are
always better than the loss involved in the previous algorithm (on average, we observe
a substantial gain of around 20%), while the compression rates are equivalent.
dcc2016poster.pdf (452.79 Ko)
Télécharger le fichier
dcc2016abstract.pdf (84.62 Ko)
