DP: Dynamic Prepage in Postcopy Migration for Fixed-Size Data Load - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shuang Wu
  • Fonction : Auteur
  • PersonId : 994402
Ce Yang
  • Fonction : Auteur
  • PersonId : 994403
Jianhai Chen
  • Fonction : Auteur
  • PersonId : 994404
Qinming He
  • Fonction : Auteur
  • PersonId : 994405
Bei Wang
  • Fonction : Auteur
  • PersonId : 994406
Postcopy migration is a mature technology in virtualization. However the performance of postcopy is not stable. We find many memory intensive loads having a high proportion of independent fixed-size data (FSD) cases. To improve migration performance, we present DP: an algorithm which applies to intelligently tackle FSD load during postcopy migration. We implement DP as an online algorithm triggered by remote paging, and adjusting to prepage the most appropriate amount of pages related to recent page fault records. DP also has a threshold processing mechanism to prevent from noise which is derived from load size fluctuation. The experimental results show that DP algorithm can significantly reduce response time and implicit downtime in postcopy migration, with an high improvement on QoS.
978-3-662-44917-2_45_Chapter.pdf (150.66 Ko) Télécharger le fichier
hal-01403132 , version 1 (25-11-2016)
Paternité
Shuang Wu, Ce Yang, Jianhai Chen, Qinming He, Bei Wang. DP: Dynamic Prepage in Postcopy Migration for Fixed-Size Data Load. 11th IFIP International Conference on Network and Parallel Computing (NPC), Sep 2014, Ilan, Taiwan. pp.530-533, ⟨10.1007/978-3-662-44917-2_45⟩. ⟨hal-01403132⟩
41 Consultations
84 Téléchargements
