An Estimation-Based Task Load Balancing Scheduling in Spot Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2014
Daeyong Jung
  • Function : Author
  • PersonId : 994420
Heeseok Choi
  • Function : Author
  • PersonId : 994421
Daewon Lee
  • Function : Author
  • PersonId : 994362
Heonchang Yu
  • Function : Author
  • PersonId : 994363
Eunyoung Lee
  • Function : Author
  • PersonId : 994422
Cloud computing is a computing paradigm in which users can rent computing resources from service providers according to their requirements. Cloud computing based on the spot market helps a user to obtain resources at a lower cost. However, these resources may be unreliable. In this paper, we propose an estimation-based distributed task workflow scheduling scheme that reduces the estimated generation compared to Genetic Algorithm (GA). Moreover, our scheme executes a user’s job within selected instances and stretches the user’s cost. The simulation results, based on a before-and-after estimation comparison, reveal that the task size is determined based on the performance of each instance and the task is distributed among the different instances. Therefore, our proposed estimation-based task load balancing scheduling technique achieves the task load balancing according to the performance of instances.
978-3-662-44917-2_55_Chapter.pdf (217.1 Ko) Télécharger le fichier
Dates and versions
hal-01403147 , version 1 (25-11-2016)
Attribution
Identifiers
Cite
Daeyong Jung, Heeseok Choi, Daewon Lee, Heonchang Yu, Eunyoung Lee. An Estimation-Based Task Load Balancing Scheduling in Spot Clouds. 11th IFIP International Conference on Network and Parallel Computing (NPC), Sep 2014, Ilan, Taiwan. pp.571-574, ⟨10.1007/978-3-662-44917-2_55⟩. ⟨hal-01403147⟩
42 View
48 Download
Share
