An Adaptive Heterogeneous Runtime for Irregular Applications in the Case of Ray-Tracing (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wei-Chung Hsu
  • Fonction : Auteur
  • PersonId : 994428
Heterogeneous architecture has been widely adopted in various computing systems, from mobile devices to servers. However, optimizing the performance for such platforms remains challenging in three aspects: the control flow divergence decreases the utilization of SIMD components, the significant memory copy overhead between computing devices consuming precious memory bandwidth and the load imbalance that degrades the overall performance.
978-3-662-44917-2_63_Chapter.pdf (116.41 Ko) Télécharger le fichier
hal-01403162 , version 1 (25-11-2016)
Paternité
Chih-Chen Kao, Wei-Chung Hsu. An Adaptive Heterogeneous Runtime for Irregular Applications in the Case of Ray-Tracing (Extended Abstract). 11th IFIP International Conference on Network and Parallel Computing (NPC), Sep 2014, Ilan, Taiwan. pp.604-607, ⟨10.1007/978-3-662-44917-2_63⟩. ⟨hal-01403162⟩
35 Consultations
66 Téléchargements
