Residual Schemes Applied to an Embedded Method Expressed on Unstructured Adapted Grids - Archive ouverte HAL Access content directly
Journal Articles Kongqi Donglixue Xuebao: Acta Aerodynamica Sinica Year : 2016
(1, 2) , (2) , (2) , (2) , (2)
1
2
The interest on embedded boundary methods is increasing in Computational Fluid Dynamics because they simplify the mesh generation problem when dealing with the Navier-Stokes equations. To give a few examples, they simplify the simulation of multi-physics flows, the coupling of fluid-solid interactions in situation of large motions or deformations. Nevertheless an accurate treatment of the wall boundary conditions remains an issue of the method. In this work, a penalty term added to the Navier-Stokes equations accounts for the wall boundary conditions and accuracy is recovered using mesh adaptation, thanks to the potential of unstructured meshes.
Not file
Dates and versions
hal-01407945 , version 1 (02-12-2016)
Identifiers
Cite
Rémi Abgrall, Hubert Alcin, Heloise Beaugendre, Cecile Dobrzynski, Leo Nouveau. Residual Schemes Applied to an Embedded Method Expressed on Unstructured Adapted Grids. Kongqi Donglixue Xuebao: Acta Aerodynamica Sinica, 2016, 34 (2), pp.214-223. ⟨10.7638/kqdlxxb-2016.0010⟩. ⟨hal-01407945⟩
372 View
0 Download
Share
