The Period adding and incrementing bifurcations: from rotation theory to applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Review Année : 2017
This survey article is concerned with the study of bifurcations of discontinuous piecewise-smooth maps, with a special focus on the one-dimensional case. We review the literature on circle maps and quasi-contractions and provide paths through this literature to prove sufficient conditions for the occurrence of two types of bifurcation scenarios involving rich dynamics. The first scenario consists of the appearance of periodic orbits whose symbolic sequences and “rotation” numbers follow a Farey tree structure; the periods of the periodic orbits are given by consecutive addition. This is called the period adding bifurcation, and the proof of its existence relies on results for maps on the circle. In the second scenario, symbolic sequences are obtained by consecutive attachment of a given symbolic block, and the periods of periodic orbits are incremented by a constant term. This is called the period incrementing bifurcation, and its proof relies on results for maps on the interval. We also discuss the expanding cases, as some of the partial results found in the literature also hold when these maps lose contractiveness. The higher-dimensional case is also discussed by means of quasi-contractions. We provide applied examples in control theory, power electronics, and neuroscience, where these results can be used to obtain precise descriptions of their dynamics.
1407.1895v3.pdf (5.5 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01416249 , version 1 (04-01-2017)
  • HAL Id : hal-01416249 , version 1
Albert Granados, Lluís Alsedà, Martin Krupa. The Period adding and incrementing bifurcations: from rotation theory to applications. SIAM Review, 2017, 59 (2), pp.225-292. ⟨hal-01416249⟩
540 Consultations
383 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
