A unified approach to Nevanlinna-Pick interpolation problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work deals with Complex-valued interpolation by a Schur rational function of given degree at a set of nodes located in the closed lower half-plane, with prescribed maximum points for the modulus (i.e. points where it is equal to 1) on the real axis. The motivation comes from broadband matching, for which the technique we develop offers a new tool.
Baratchart_Olivi_Seyfert_MTNS16.pdf (184.38 Ko) Télécharger le fichier
hal-01420880 , version 1 (21-12-2016)
  • HAL Id : hal-01420880 , version 1
Laurent Baratchart, Martine Olivi, Fabien Seyfert. A unified approach to Nevanlinna-Pick interpolation problems. 22nd International Symposium on Mathematical Theory of Networks and Systems, Jul 2016, Mineapolis, United States. ⟨hal-01420880⟩
437 Consultations
286 Téléchargements
