Stable broken H1 and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We study extensions of piecewise polynomial data prescribed on faces and possibly in elements of a patch of simplices sharing a vertex. In the H1 setting, we look for functions whose jumps across the faces are prescribed, whereas in the H(div) setting, the normal component jumps and the piecewise divergence are prescribed. We show stability in the sense that the minimizers over piecewise polynomial spaces of the same degree as the data are subordinate in the broken energy norm to the minimizers over the whole broken H1 and H(div) spaces. Our proofs are constructive and yield constants independent of the polynomial degree. One particular application of these results is in a posteriori error analysis, where the present results justify polynomial-degree-robust efficiency of potential and flux reconstructions.
robust_rev.pdf (756.99 Ko) Télécharger le fichier
hal-01422204 , version 1 (24-12-2016)
hal-01422204 , version 2 (20-08-2018)
hal-01422204 , version 3 (29-09-2019)
hal-01422204 , version 4 (04-10-2019)
  • HAL Id : hal-01422204 , version 2
Alexandre Ern, Martin Vohralík. Stable broken H1 and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions. 2018. ⟨hal-01422204v2⟩
558 Consultations
246 Téléchargements
