Stable broken $H^1$ and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2019
We study extensions of piecewise polynomial data prescribed on faces and possibly in elements of a patch of simplices sharing a vertex. In the $H^1$ setting, we look for functions whose jumps across the faces are prescribed, whereas in the H(div) setting, the normal component jumps and the piecewise divergence are prescribed. We show stability in the sense that the minimizers over piecewise polynomial spaces of the same degree as the data are subordinate in the broken energy norm to the minimizers over the whole broken $H^1$ and H(div) spaces. Our proofs are constructive and yield constants independent of the polynomial degree. One particular application of these results is in a posteriori error analysis, where the present results justify polynomial-degree-robust efficiency of potential and flux reconstructions.
robust_HAL.pdf (759.77 Ko) Télécharger le fichier
hal-01422204 , version 1 (24-12-2016)
hal-01422204 , version 2 (20-08-2018)
hal-01422204 , version 3 (29-09-2019)
hal-01422204 , version 4 (04-10-2019)
  • HAL Id : hal-01422204 , version 3
Alexandre Ern, Martin Vohralík. Stable broken $H^1$ and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions. Mathematics of Computation, In press. ⟨hal-01422204v3⟩
558 Consultations
247 Téléchargements
