Very High Order Anisotropic Metric-Based Mesh Adaptation in 3D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Procedia Engineering Année : 2016
In this paper, we study the extension of anisotropic metric-based mesh adaptation to the case of very high-order solutions in 3D. This work is based on an extension of the continuous mesh framework and multi-scale mesh adaptation where the optimal metric is derived through a calculus of variation. Based on classical high order a priori error estimates, the point-wise leading term of the local error is a homogeneous polynomial of order k + 1. To derive the leading anisotropic direction and orientations, this polynomial is approximated by a quadratic positive definite form, taken to the power k+1 2. From a geometric point of view, this problem is equivalent to finding a maximal volume ellipsoid included in the level set one of the absolute value of the polynomial. This optimization problem is strongly non-linear both for the functional and the constraints. We first recast the continuous problem in a discrete setting in the metric-logarithm space. With this approximation, this problem becomes linear and is solved with the simplex algorithm. This optimal quadratic form in the Euclidean space is then found by iteratively solving a sequence of such log-simplex problems. From the field of the local quadratic forms that representing the high-order error, a calculus of variation is used to globally control the error in L p norm. A closed form of the optimal metric is then found. Anisotropic meshes are then generated with this metric based on the unit mesh concept. For the numerical experiments, we consider several analytical functions in 3D. Convergence rate and optimality of the meshes are then discussed for interpolation of orders 1 to 5.
IMR2016Final.pdf (5.88 Mo) Télécharger le fichier
hal-01438226 , version 1 (17-01-2017)
Adrien Loseille, Olivier Coulaud. Very High Order Anisotropic Metric-Based Mesh Adaptation in 3D. Procedia Engineering, 2016, 25th International Meshing Roundtable, 163, pp.353 - 365. ⟨10.1016/j.proeng.2016.11.071⟩. ⟨hal-01438226⟩
345 Consultations
113 Téléchargements
