Didactical formulation of the Ampère law
The Ampère law is useful to calculate the magnetostatic field in the cases of distributions of current with high degree of symmetry. Nevertheless the magnetic field produced by a thin straight wire carrying a current I requires the Biot–Savart law and the use of the Ampère law leads to a mistake. A didactical formulation of the Ampère law is proposed to prevent misinterpretations.
