A stochastic model for cell adhesion to the vascular wall - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We present here a minimal mathematical model of the interaction between a cell and the blood vessel wall in shear flow. The bond dynamics in cell adhesion is modeled as a non-linear discrete stochastic process. Performing a renormalization in the spirit of [22, 11], we obtain a continuous model which predicts the existence of a threshold shear velocity associated with cell rolling and a process of firm adhesion that follows the initial rolling.
Ligand_Etchegaray_Meunier_hal.pdf (1.03 Mo) Télécharger le fichier
hal-01442975 , version 1 (23-01-2017)
hal-01442975 , version 2 (18-02-2019)
hal-01442975 , version 3 (12-12-2019)
Christèle Etchegaray, Nicolas Meunier. A stochastic model for cell adhesion to the vascular wall. 2017. ⟨hal-01442975v1⟩
379 Consultations
378 Téléchargements
