A stochastic model for cell adhesion to the vascular wall - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2019
We present here a minimal mathematical model of the interaction between a cell and the blood vessel wall in shear flow. The bond dynamics in cell adhesion is modeled as a non-linear discrete stochastic process. Performing a renormalization in the spirit of [22, 11], we obtain a continuous model which predicts the existence of a threshold shear velocity associated with cell rolling and a process of firm adhesion that follows the initial rolling.
Etchegaray_Meunier.pdf (980.77 Ko) Télécharger le fichier
hal-01442975 , version 1 (23-01-2017)
hal-01442975 , version 2 (18-02-2019)
hal-01442975 , version 3 (12-12-2019)
Christèle Etchegaray, Nicolas Meunier. A stochastic model for cell adhesion to the vascular wall. Journal of Mathematical Biology, 2019. ⟨hal-01442975v2⟩
Collections
LM-ORSAY MAP5
379 Consultations
383 Téléchargements
