Hardy-Hodge Decomposition of Vector Fields in R$^{n}$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions of the American Mathematical Society Année : 2018
We prove that a R^(n+1)-valued vector field on R^n is the sum of the traces of two harmonic gradients, one in each component of R^(n+1) \ R^n , and of a R^n-valued divergence free vector field. We apply this to the description of vanishing potentials in divergence form. The results are stated in terms of Clifford Hardy spaces, the structure of which is important for our study.
BDQ2016_submitted.pdf (326.94 Ko) Télécharger le fichier
hal-01462960 , version 1 (14-02-2017)
Laurent Baratchart, Pei Dang, Tao Qian. Hardy-Hodge Decomposition of Vector Fields in R$^{n}$. Transactions of the American Mathematical Society, 2018, 370 (3), pp.2005 - 2022. ⟨10.1090/tran/7202⟩. ⟨hal-01462960⟩
196 Consultations
201 Téléchargements
