Revisiting Benders Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Benders decomposition entails a two-stage optimization approach to a mixed integer program: first-stage decision variables are optimized using a polyhedral approximation of the problem's projection; then a separation problem expressed in the second-stage variables is solved to check if the current first-stage solution is feasible; otherwise, it produces a violated inequality. Such cutting-plane algorithm can suffer severe drawbacks regarding its convergence rate. We review the battery of approaches that have been proposed in the literature to address these drawbacks and to speed-up the algorithm. Our contribution consists in proposing a unified framework to explain these techniques, showing that in several cases, different proposals of the literature boil down to the same key ideas. We complete this review with a numerical study of implementation options for Benders algorithmic features and enhancements.
Fichier non déposé
hal-01467283 , version 1 (14-02-2017)
  • HAL Id : hal-01467283 , version 1
Boris Detienne, Ruslan Sadykov, Halil Şen, Francois Vanderbeck. Revisiting Benders Decomposition. Symposium Combinatorial Optimization and Applications, Feb 2017, Edinburgh, United Kingdom. ⟨hal-01467283⟩
315 Consultations
0 Téléchargements
