Time-Varying Parameter Identification Algorithms: Finite and Fixed-Time Convergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2018
In this paper the problem of time-varying parameter identification is studied. To this aim, two identification algorithms are developed in order to identify time-varying parameters in a finite-time or prescribed time (fixed-time). The convergence proofs are based on a notion of finite-time stability over finite intervals of time, i.e. Short-finite-time stability; homogeneity for time-varying systems; and Lyapunov-based approach. The results are obtained under injectivity of the regressor term, which is related to the classical identifiability condition. The case of bounded disturbances (noise of measurements) is analyzed for both algorithms. Simulation results illustrate the feasibility of the proposed algorithms.
_LTV_ParIdent_FxT_TAC_FV.pdf (1.65 Mo) Télécharger le fichier
hal-01470957 , version 1 (18-02-2017)
Hector Ríos, Denis Efimov, Jaime A Moreno, Wilfrid Perruquetti, J G Rueda-Escobedo. Time-Varying Parameter Identification Algorithms: Finite and Fixed-Time Convergence. IEEE Transactions on Automatic Control, 2018, ⟨10.1109/TAC.2017.2673413⟩. ⟨hal-01470957⟩
861 Consultations
790 Téléchargements
