Uniform L ∞ estimates for approximate solutions of the bipolar drift-diffusion system
We establish uniform L ∞ bounds for approximate solutions of the drift-diffusion system for electrons and holes in semiconductor devices, computed with the Schar-fetter-Gummel finite-volume scheme. The proof is based on a Moser iteration technique adapted to the discrete case.
Analyse numérique [math.NA]
