Mahalanobis Distance-Based Algorithm for Ellipse Growing in Iris Preprocessing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a new algorithm for ellipse recognition. The approach uses Mahalanobis distance and statistical and analytical properties of circular and elliptical objects. At first stage of the algorithm the starting configuration of initial ellipse is defined. Next we apply a condition which describes how much the shape is ellipse-like on the boundary points.The algorithm can be easily applied to detection of elliptical objects also on grayscale images. Moreover, we discuss the improvement in iris image preprocessing.
978-3-642-40925-7_16_Chapter.pdf (779.72 Ko) Télécharger le fichier
hal-01496062 , version 1 (27-03-2017)
Paternité
Krzysztof Misztal, Jacek Tabor. Mahalanobis Distance-Based Algorithm for Ellipse Growing in Iris Preprocessing. 12th International Conference on Information Systems and Industrial Management (CISIM), Sep 2013, Krakow, Poland. pp.158-167, ⟨10.1007/978-3-642-40925-7_16⟩. ⟨hal-01496062⟩
116 Consultations
1701 Téléchargements
