The Data Exploration System for Image Processing Based on Server-Side Operations
In this paper the possibilities for construction of an ad hoc search system to examine large-sized raster image data sets, e.g. rock images or medical images, for analysis of its characteristic parameters are presented. A new solution for image exploration based on any attributes extracted with computer image analysis by using extensions for server-side operations is proposed.
