Growing Neural Gas – A Parallel Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lukáš Vojáček
  • Fonction : Auteur
  • PersonId : 994859
Jiří Dvorský
  • Fonction : Auteur
  • PersonId : 994861
The paper deals with the high dimensional data clustering problem. One possible way to cluster this kind of data is based on Artificial Neural Networks (ANN) such as SOM or Growing Neural Gas (GNG). The learning phase of the ANN, which is time-consuming especially for large high-dimensional datasets, is the main drawback of this approach to data clustering. The parallel modification, Growing Neural Gas, and its implementation on the HPC cluster is presented in the paper. Some experimental results are also presented.
978-3-642-40925-7_38_Chapter.pdf (834.05 Ko) Télécharger le fichier
hal-01496086 , version 1 (27-03-2017)
Paternité
Lukáš Vojáček, Jiří Dvorský. Growing Neural Gas – A Parallel Approach. 12th International Conference on Information Systems and Industrial Management (CISIM), Sep 2013, Krakow, Poland. pp.408-419, ⟨10.1007/978-3-642-40925-7_38⟩. ⟨hal-01496086⟩
154 Consultations
720 Téléchargements
