Searching in the Structured Space of the Braille Music
This paper presents a method for searching the Braille music information based on the semantic description. The searching method is based on comparison of node’s metadata that aggregates subtree’s structure of information. Methods for the metadata generation is specific to searching orientation and grammar. We focus on methods for notes’ durations allocation as well as key and time distribution that are required in searching and rhythm analysis. We propose a syntax analysis method based on semantic analysis using attribute grammar.
