The entropic regularization of the Monge problem on the real line
We study the entropic regularization of the optimal transport problem in dimension 1 when the cost function is the distance c(x, y) = |y − x|. The selected plan at the limit is, among those which are optimal for the non-penalized problem, the most " diffuse " one on the zones where it may have a density.
