The entropic regularization of the Monge problem on the real line - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2018
We study the entropic regularization of the optimal transport problem in dimension 1 when the cost function is the distance c(x, y) = |y − x|. The selected plan at the limit is, among those which are optimal for the non-penalized problem, the most " diffuse " one on the zones where it may have a density.
monge-entropic-final.pdf (352.56 Ko) Télécharger le fichier
hal-01498732 , version 1 (30-03-2017)
hal-01498732 , version 2 (08-10-2017)
hal-01498732 , version 3 (30-01-2018)
hal-01498732 , version 4 (16-08-2018)
Simone Di Marino, Jean Louet. The entropic regularization of the Monge problem on the real line. SIAM Journal on Mathematical Analysis, In press. ⟨hal-01498732v3⟩
635 Consultations
367 Téléchargements
