Optimized Binary64 and Binary128 Arithmetic with GNU MPFR
We describe algorithms used to optimize the GNU MPFR library when the operands fit into one or two words. On modern processors, a correctly rounded addition of two quadruple precision numbers is now performed in 22 cycles, a subtraction in 24 cycles, a multiplication in 32 cycles, a division in 64 cycles, and a square root in 69 cycles. We also introduce a new faithful rounding mode, which enables even faster computations. Those optimizations will be available in version 4 of MPFR.
