pycobra: A Python toolkit for ensemble regression analysis and visualisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Benjamin Guedj
We introduce pycobra, a Python library devoted to ensemble regression and visualisation. Its main assets are the implementation of the COBRA algorithm (an ensemble method introduced by Biau et al., 2016), a flexible and generic interface to compare most regression methods available in Python libraries (including, but not limited to, scikit-learn), and visualisation tools based on Voronoi tessellations. pycobra is released under the MIT open-source license and can be downloaded from the Python Package Index (PyPi) and Machine Learning Open Source Software. The current development (along with Jupyter notebooks) is available at https://github.com/bhargavvader/pycobra.
main-pycobra.pdf (953.43 Ko) Télécharger le fichier
hal-01514059 , version 1 (25-04-2017)
hal-01514059 , version 2 (27-07-2017)
hal-01514059 , version 3 (20-06-2018)
Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
  • HAL Id : hal-01514059 , version 1
Benjamin Guedj, Bhargav Srinivasa Desikan. pycobra: A Python toolkit for ensemble regression analysis and visualisation. 2017. ⟨hal-01514059v1⟩
1135 Consultations
536 Téléchargements
