Realization and Discretization of Asymptotically Stable Homogeneous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2017
Sufficient conditions for the existence and convergence to zero of numeric approximations to solutions of asymptotically stable homogeneous systems are obtained for the explicit and implicit Euler integration schemes. It is shown that the explicit Euler method has certain drawbacks for the global approximation of homogeneous systems with non-zero degrees, whereas the implicit Euler scheme ensures convergence of the approximating solutions to zero. Properties of absolute and relative errors of the respective discretizations are investigated.
Homo_Euler_J.pdf (1.14 Mo) Télécharger le fichier
hal-01514350 , version 1 (26-04-2017)
Denis Efimov, Andrey Polyakov, Arie Levant, Wilfrid Perruquetti. Realization and Discretization of Asymptotically Stable Homogeneous Systems. IEEE Transactions on Automatic Control, 2017, 62 (11), pp.5962 - 5969. ⟨10.1109/TAC.2017.2699284⟩. ⟨hal-01514350⟩
974 Consultations
429 Téléchargements
