The Mayer and Minimum Time Problems with Stratified State Constraints * - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Set-Valued and Variational Analysis Année : 2017
This paper studies optimal control problems with state constraints by imposing structural assumptions on the constraint domain coupled with a tangential restriction with the dynamics. These assumptions replace pointing or controllability assumptions that are common in the literature, and provide a framework under which feasible boundary trajectories can be analyzed directly. The value functions associated with the state constrained Mayer and minimal time problems are characterized as solutions to a pair of Hamilton-Jacobi inequalities with appropriate boundary conditions. The novel feature of these inequalities lies in the choice of the Hamiltonian.
VERSIONMar2017.pdf (352.9 Ko) Télécharger le fichier
hal-01517510 , version 1 (09-05-2017)
C. Hermosilla, P.R. Wolenski, Hasnaa Zidani. The Mayer and Minimum Time Problems with Stratified State Constraints *. Set-Valued and Variational Analysis, 2017, ⟨10.1007/s11228-017-0413-z⟩. ⟨hal-01517510⟩
410 Consultations
325 Téléchargements
