The Mayer and Minimum Time Problems with Stratified State Constraints *
This paper studies optimal control problems with state constraints by imposing structural assumptions on the constraint domain coupled with a tangential restriction with the dynamics. These assumptions replace pointing or controllability assumptions that are common in the literature, and provide a framework under which feasible boundary trajectories can be analyzed directly. The value functions associated with the state constrained Mayer and minimal time problems are characterized as solutions to a pair of Hamilton-Jacobi inequalities with appropriate boundary conditions. The novel feature of these inequalities lies in the choice of the Hamiltonian.
