A Statistical-Topological Feature Combination for Recognition of Isolated Hand Gestures from Kinect Based Depth Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reliable hand gesture recognition is an important problem for automatic sign language recognition for the people with hearing and speech disabilities. In this paper, we create a new benchmark database of multi-oriented, isolated ASL numeric images using recently launched Kinect V2. Further, we design an effective statistical-topological feature combinations for recognition of the hand gestures using the available V1 sensor dataset and also over the new V2 dataset. For V1, our best accuracy is 98.4% which is comparable with the best one reported so far and for V2 we achieve an accuracy of 92.2% which is first of its kind.
paper29.pdf (569.7 Ko) Télécharger le fichier
hal-01517817 , version 1 (03-05-2017)
Soumi Paul, Hayat Nasser, Mita Nasipuri, Phuc Ngo, Subhadip Basu, et al.. A Statistical-Topological Feature Combination for Recognition of Isolated Hand Gestures from Kinect Based Depth Images. IWCIA, Jun 2017, Plovdiv, Bulgaria. ⟨10.1007/978-3-319-59108-7⟩. ⟨hal-01517817⟩
299 Consultations
344 Téléchargements
