Optimization of Initial Centroids for K-Means Algorithm Based on Small World Network - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
K-means algorithm is a relatively simple and fast gather clustering algorithm. However, the initial clustering center of the traditional k-means algorithm was generated randomly from the dataset, and the clustering result was unstable. In this paper, we propose a novel method to optimize the selection of initial centroids for k-means algorithm based on the small world network. This paper firstly models a text document set as a network which has small world phenomenon and then use small-world’s characteristics to form k initial centroids. Experimental evaluation on documents croups show clustering results (total cohesion, purity, recall) obtained by proposed method comparable with traditional k-means algorithm. The experiments show that results are obtained by the proposed algorithm can be relatively stability and efficiency. Therefore, this method can be considered as an effective application in the domain of text documents, especially in using text clustering for topic detection.
978-3-642-32891-6_13_Chapter.pdf (299.99 Ko) Télécharger le fichier
Dates and versions
hal-01524955 , version 1 (19-05-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Shimo Shen, Zuqiang Meng. Optimization of Initial Centroids for K-Means Algorithm Based on Small World Network. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.87-96, ⟨10.1007/978-3-642-32891-6_13⟩. ⟨hal-01524955⟩
480 View
261 Download
Share
