A Novel Model for Semantic Learning and Retrieval of Images
In this paper, we firstly propose an extended probabilistic latent semantic analysis (PLSA) to model continuous quantity. In addition, corresponding EM algorithm is derived to determine the parameters. Then, we apply this model in automatic image annotation. In order to deal with the data of different modalities according to their characteristics, we present a semantic annotation model which employs continuous PLSA and traditional PLSA to model visual features and textual words respectively. These two models are linked with the same distribution over all aspects. Furthermore, an asymmetric learning approach is adopted to estimate the model parameters. This model can predict semantic annotation well for an unseen image because it associates visual and textual modalities more precisely and effectively. We evaluate our approach on the Corel5k and Corel30k dataset. The experiment results show that our approach outperforms several state-of-the-art approaches.
