Query Expansion Based-on Similarity of Terms for Improving Arabic Information Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Khaled Shaalan
  • Fonction : Auteur
  • PersonId : 1008503
Sinan Al-Sheikh
  • Fonction : Auteur
  • PersonId : 1008504
Farhad Oroumchian
  • Fonction : Auteur
  • PersonId : 1008505
This research suggests a method for query expansion on Arabic Information Retrieval using Expectation Maximization (EM). We employ the EM algorithm in the process of selecting relevant terms for expanding the query and weeding out the non-related terms. We tested our algorithm on INFILE test collection of CLLEF2009, and the experiments show that query expansion that considers similarity of terms both improves precision and retrieves more relevant documents. The main finding of this research is that we can increase the recall while keeping the precision at the same level by this method.
978-3-642-32891-6_22_Chapter.pdf (196.79 Ko) Télécharger le fichier
hal-01524973 , version 1 (19-05-2017)
Paternité
Khaled Shaalan, Sinan Al-Sheikh, Farhad Oroumchian. Query Expansion Based-on Similarity of Terms for Improving Arabic Information Retrieval. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.167-176, ⟨10.1007/978-3-642-32891-6_22⟩. ⟨hal-01524973⟩
60 Consultations
284 Téléchargements
