Analysis on Limitation Origins of Information Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The limitations of Shannon information theory are pointed out from new perspectives. The limitations mainly exist in the neglects of the information reliability and completeness. The significances of the information reliability to the information measurements are further illustrated through example analysis. It is pointed out that such limitations originate from neglects of multi-level information uncertainties, uncertainty of the model and other objects of information system, and insufficient knowledge on uncertainties of probability values.
978-3-642-32891-6_9_Chapter.pdf (63.52 Ko) Télécharger le fichier
hal-01524976 , version 1 (19-05-2017)
Paternité
Yong Wang, Huadeng Wang, Qiong Cao. Analysis on Limitation Origins of Information Theory. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.50-57, ⟨10.1007/978-3-642-32891-6_9⟩. ⟨hal-01524976⟩
70 Consultations
760 Téléchargements
