Inverse dynamics based on occlusion-resistant Kinect data: Is it usable for ergonomics? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Industrial Ergonomics Année : 2017
Joint torques and forces are relevant quantities to estimate the biomechanical constraints of working tasks in ergonomics. However, inverse dynamics requires accurate motion capture data, which are generally not available in real manufacturing plants. Markerless and calibrationless measurement systems based on depth cameras, such as the Microsoft Kinect, are promising means to measure 3D poses in real time. Recent works have proposed methods to obtain reliable continuous skeleton data in cluttered environments, with occlusions and inappropriate sensor placement. In this paper, we evaluate the reliability of an inverse dynamics method based on this corrected skeleton data and its potential use to estimate joint torques and forces in such cluttered environments. To this end, we compared the calculated joint torques with those obtained with a reference inverse dynamics method based on an optoelectronic motion capture system. Results show that the Kinect skeleton data enabled the inverse dynamics process to deliver reliable joint torques in occlusion-free (r=0.99 for the left shoulder elevation) and occluded (r=0.91 for the left shoulder elevation) environments. However, differences remain between joint torques estimations. Such reliable joint torques open appealing perspectives for the use of new fatigue or solicitation indexes based on internal efforts measured on site.Relevance to industry: The study demonstrates that corrected Kinect data could be used to estimate internal joint torques, using an adapted inverse dynamics method. The method could be applied on-site because it can handle some cases with occlusions. The resulting Kinect-based method is easy-to-use, real-time and could assist ergonomists in risk evaluation on site.
Plantard_etal_IJIE_2017.pdf (894.33 Ko) Télécharger le fichier
hal-01527325 , version 1 (24-05-2017)
Pierre Plantard, Antoine Muller, Charles Pontonnier, Georges Dumont, Hubert P H Shum, et al.. Inverse dynamics based on occlusion-resistant Kinect data: Is it usable for ergonomics?. International Journal of Industrial Ergonomics, 2017, 61, pp.71-80. ⟨10.1016/j.ergon.2017.05.010⟩. ⟨hal-01527325⟩
532 Consultations
256 Téléchargements
