Optimal rate of convergence of an ODE associated to the Fast Gradient Descent schemes for b>0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Jf Aujol
This paper is devoted to the study of an ODE associated to FISTA. New vonvergence results are presented, even in the case of non convex functions. The asymptotic rate are proven to be optimal with the study of particular instances. Robustness to noise is also investigated.
EquaDiffv9bis.pdf (241.17 Ko) Télécharger le fichier
hal-01547251 , version 1 (26-06-2017)
hal-01547251 , version 2 (17-07-2017)
  • HAL Id : hal-01547251 , version 2
Jf Aujol, Ch Dossal. Optimal rate of convergence of an ODE associated to the Fast Gradient Descent schemes for b>0. 2017. ⟨hal-01547251v2⟩
407 Consultations
674 Téléchargements
