A Multi-Faceted Approach to Analyse the Effects of Environmental Variables on Geographic Range and Genetic Structure of a Perennial Psammophilous Geophyte: The Case of the Sea Daffodil Pancratium maritimum L. in the Mediterranean Basin - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2016
Vela_etal_PlosOne_2016_11_10.pdf (2.76 Mo) Télécharger le fichier
hal-01549690 , version 1 (29-06-2017)
Olga de Castro, Antonietta Di Maio, Mirko Di Febbraro, Gennaro Imparato, Michele Innangi, et al.. A Multi-Faceted Approach to Analyse the Effects of Environmental Variables on Geographic Range and Genetic Structure of a Perennial Psammophilous Geophyte: The Case of the Sea Daffodil Pancratium maritimum L. in the Mediterranean Basin. PLoS ONE, 2016, 11 (10), pp.e0164816. ⟨10.1371/journal.pone.0164816.s003⟩. ⟨hal-01549690⟩
335 Consultations
286 Téléchargements
