Addendum to "Local Controllability of the Two-Link Magneto-Elastic Micro-Swimmer" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2018
In the above mentioned note (hal-01145537, arXiv:1506.05918, published in IEEE Trans. Autom. Cont., 2017), the first and fourth authors proved a local controllability result around the straight configuration for a class of magneto-elastic micro-swimmers. That result is weaker than the usual small-time local controllability (STLC), and the authors left the STLC question open. The present addendum closes it by showing that these systems cannot be STLC.
addendumIEEE-HAL.pdf (123.79 Ko) Télécharger le fichier
hal-01553296 , version 1 (03-07-2017)
Laetitia Giraldi, Pierre Lissy, Clément Moreau, Jean-Baptiste Pomet. Addendum to "Local Controllability of the Two-Link Magneto-Elastic Micro-Swimmer". IEEE Transactions on Automatic Control, 2018, 63 (7), pp.2303-2305. ⟨10.1109/TAC.2017.2764422⟩. ⟨hal-01553296⟩
321 Consultations
141 Téléchargements
