Shapley effects for sensitivity analysis with dependent inputs: comparisons with Sobol' indices, numerical estimation and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The global sensitivity analysis of a numerical model consists in quantifying, by means of sensitivity indices, the contributions of each of its input variables to the output the variability. The popular Sobol' indices, which are based on the functional variance analysis, present a difficult interpretation in the presence of statistical dependence between inputs. The recently introduced Shapley effects (normalized variance-based Shapley values), which consist of allocating a part of the variance of the output at each input, represent a promising alternative to solve this problem. In this paper, using several new analytical results, we study the effects of linear correlation between some Gaussian input variables on Shapley effects, and compare these effects to classical first-order and total Sobol' indices. This illustrates the interest, in terms of sensitivity analysis setting and interpretation, of the Shapley effects in the case of dependent inputs. We also investigate the numerical convergence of the estimated Shapley effects. For the practical issue of computationally expensive engineering models, we show that the substitution of the original model by a metamodel (here, kriging) makes it possible to estimate these indices with precision at a reasonable computational cost.
RESS17-ioossPrieur.pdf (702.8 Ko) Télécharger le fichier
geomCNDsoudure2.pdf (105.91 Ko) Télécharger le fichier
shapley-CNDUS.pdf (2 Ko) Télécharger le fichier
shapleyCvgExa_lingaus.pdf (4.36 Ko) Télécharger le fichier
shapleyCvgRand_lingaus.pdf (13.27 Ko) Télécharger le fichier
shapleyExpExa_lingaus.pdf (7.78 Ko) Télécharger le fichier
shapleyExpRand_lingaus.pdf (7.78 Ko) Télécharger le fichier
shapleyTh_lin2d_gaus11.pdf (5.43 Ko) Télécharger le fichier
shapleyTh_lin2d_gaus12.pdf (6.05 Ko) Télécharger le fichier
shapleyTh_lingaus.pdf (7.27 Ko) Télécharger le fichier
shapleyTh_linintgaus.pdf (6.71 Ko) Télécharger le fichier
simul_orientations.pdf (123.17 Ko) Télécharger le fichier
soudure.pdf (121.67 Ko) Télécharger le fichier
testMM_ishig.pdf (3.29 Ko) Télécharger le fichier
test_ishig12.pdf (7.52 Ko) Télécharger le fichier
test_ishig13.pdf (7.59 Ko) Télécharger le fichier
test_ishig23.pdf (7.41 Ko) Télécharger le fichier
hal-01556303 , version 1 (04-07-2017)
hal-01556303 , version 2 (02-10-2017)
hal-01556303 , version 3 (22-02-2018)
hal-01556303 , version 4 (17-05-2018)
hal-01556303 , version 5 (17-01-2019)
hal-01556303 , version 6 (21-03-2019)
hal-01556303 , version 7 (23-11-2019)
Bertrand Iooss, Clémentine Prieur. Shapley effects for sensitivity analysis with dependent inputs: comparisons with Sobol' indices, numerical estimation and applications. 2017. ⟨hal-01556303v2⟩
1641 Consultations
3079 Téléchargements
