Shapley effects for sensitivity analysis with dependent inputs: comparisons with Sobol' indices, numerical estimation and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
The global sensitivity analysis of a numerical model aims to quantify, by means of sensitivity indices estimate, the contributions of each uncertain input variable to the model output uncertainty. The so-called Sobol' indices, which are based on the functional variance analysis, present a difficult interpretation in the presence of statistical dependence between inputs. The Shapley effect was recently introduced to overcome this problem as they allocate the mutual contribution (due to correlation and interaction) of a group of inputs to each individual input within the group. In this paper, using several new analytical results, we study the effects of linear correlation between some Gaussian input variables on Shapley effects, and compare these effects to classical first-order and total Sobol' indices. This illustrates the interest, in terms of sensitivity analysis setting and interpretation, of the Shapley effects in the case of dependent inputs. We also investigate the numerical convergence of the estimated Shapley effects. For the practical issue of computationally demanding computer models, we show that the substitution of the original model by a metamodel (here, kriging) makes it possible to estimate these indices with precision at a reasonable computational cost.
RESS17-ioossPrieur.pdf (646.65 Ko) Télécharger le fichier
hal-01556303 , version 1 (04-07-2017)
hal-01556303 , version 2 (02-10-2017)
hal-01556303 , version 3 (22-02-2018)
hal-01556303 , version 4 (17-05-2018)
hal-01556303 , version 5 (17-01-2019)
hal-01556303 , version 6 (21-03-2019)
hal-01556303 , version 7 (23-11-2019)
Bertrand Iooss, Clémentine Prieur. Shapley effects for sensitivity analysis with dependent inputs: comparisons with Sobol' indices, numerical estimation and applications. 2018. ⟨hal-01556303v3⟩
1641 Consultations
3079 Téléchargements
